Knock sensors help
Old Feb 15, 2008 | 01:05 PM
OneBadChevy's Avatar
Registered User
Default Knock sensors help
I have to replace my knock sensors. Wanted to know if there is anything else I can add to give my truck more power while I have the intake off. I already have throttle body spacer, intake, exhaust, and programmed.
Old Feb 15, 2008 | 01:26 PM
beastmode's Avatar
Import Moderator
mother fuggin knock sensors, i replaced mine about 3 times. just make sure when you do it you dont break them by over tightening them.
if thats all you have done i would say no there really nothing worth doing with the intake off except maybe gettin your throttle body P&P'd. id lose the programmer though and either try to find a local tuner in your area or get a mail order tune from one of the sponsors --------->
Old Feb 15, 2008 | 01:59 PM
00ChevyScott's Avatar
Wearin' da big hat
get rid of the TB spacer too.
Old Feb 15, 2008 | 02:04 PM
BlownChevy's Avatar
blownerator
25 Year Member
Seal your Knock Sensors up with some black RTV while you are in there. Moisture is the enemy.
Old Feb 15, 2008 | 09:11 PM
budhayes3's Avatar
PT's Slowest Truck
Yessir, there's a TSB in reference to this. Build a dam of RTV around each knock sensor to keep H2O out...
Old Feb 15, 2008 | 10:27 PM
dewmanshu's Avatar
Moderately Differentiated
I clicked on the thread to give my advise...but now I will just agree with BlownChevy and budhayes3
Old Feb 16, 2008 | 09:40 AM
Wilde Racing's Avatar
How do I change this text
Keep the spacer..
Old Feb 16, 2008 | 09:52 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by Wilde Racing
Keep the spacer..
and drill and tap it.
Old Feb 16, 2008 | 03:31 PM
SSmikeSS's Avatar
How do you know when your knock sensor is bad?
Old Feb 18, 2008 | 06:05 PM
Registered User
beastmode's Avatar
Trader Rating: 15
what do you mean local tuner or mail order tuner?
i know my knock sensors are bad due to the code the code reader brought up
