Knock sensor replacement
Back in the staging lane
How do you get the wires disconnected from the knock sensors? Is there a trick to it? I didn't want to mess up the wire trying to get the plug off. I've had a rough spell with my truck after a day of muddin a couple months ago. Here is a picture for your enjoyment. I promise they're under there somewhere.
you pull off the black rubber plug first, then you can remove the wiring ends themselves. they are oblonged shaped, you squeeze the "long" sides together a little and pull. they are the same as the old sbc knock sensor plugs.
HOLY DIRT under the manifold. One hell of a muddin time!!!!
HOLY ****- Sorry thats all I could think of.... You might want to clean that open element air filter also or replace it.
