knock sensor...
Old Nov 18, 2010 | 07:13 AM
Sc00by's Avatar
Mentioned several times before but ill mention it again........
Do NOT over tighten the knock sensors.......they are very sensitive
Do NOT drop the sensors......they are very sensitive
Replace BOTH knock sensors AND the harness (I made that mistake once by replacing one knock sensor.....4 months later and I was changing everything out again.)
As far as the RTV or sealent you decide to use on the knock sensor gromets....I RTV'd mine in place and then built a dam around the groments to help gide water around the sensors. You'll notice that your back one will probably be the worst (rusty and probably have some water in it) The foam on the bottom of the intake is up to you. I took mine off because I thought that maybe the foam was holding some water every time I wash my engine (which I do quite often).
Pimpinpete
43
Dec 22, 2017 08:13 AM
JordanH
Oct 3, 2015 03:59 PM
trevorh1
Sep 27, 2015 08:47 PM
ZxHybrid
Sep 18, 2015 04:44 PM
Pimpinpete
Sep 8, 2015 07:39 PM
