knock retard ??
Old Apr 2, 2005 | 10:02 AM
TURBHOE's Avatar
maybe i can figure something out or at least figure out what the hell the noise is.
Old Apr 5, 2005 | 07:48 PM
Its your little weak 4.8 trying to move that big truck. LOL
Mine is running AWSOME. I ran John today in my old Camaro and we were side by side. He couldnt pull on me and i couldnt pull on him. Tell Ozzy to bring it on, because I'm going to hand him his ***.
As far as that noise your truck is making, I think it could be the injectors dumping a ton of fuel when you first tap on it. It sure sounds like real knock, but just for a second.
Old Apr 5, 2005 | 08:33 PM
Black02Z71's Avatar
Your descreened maf could be causing a problem by giving incorrect load readings.
02sierraz71_5.3's Avatar
Ive got a similar sound and problems with tuning and KR I really noticed it at idle when I got under the truck (when it lopes alot). Im almost certain its from shody exhaust work, Im fixing it with my headers and ofr y install. Grab hold of the exhaust under the truck and shake it see if you hear anything, do it when its cold . If you dont at least you eliminated one thing.
Old Apr 6, 2005 | 12:24 PM
He has all stock exhaust exept for a single peice of 3" pipe in place of the muffler i gave him. The sound is more like a clatter for a split second when you first tap the gas. After that there's no strange sounds. As for the KR, when i tuned the truck i was pretty aggressive with the timing, so if you have bad fuel now, or since the temps are 40* warmer now that may cause the KR. Lets try some good gas with maybe a little booster and we'll see if the KR goes away. If not it may be false and we need to find out why.
Old Apr 7, 2005 | 05:43 PM
TURBHOE's Avatar
well i pulled alot of timming from those spots where i seen the kr from the datalog. and it still done it. it just started making that noise in arkansas not long after that long *** trip. but it didn't seem to change in performance any.
Pimpinpete
43
Dec 22, 2017 08:13 AM
dantheman1540
14
Sep 28, 2015 09:22 PM
trevorh1
Sep 27, 2015 08:47 PM
ZxHybrid
Sep 18, 2015 04:44 PM
Pimpinpete
Sep 8, 2015 07:39 PM
