just cammed engine. now it is locked up
Old Aug 1, 2022 | 06:05 PM
miguellsx's Avatar
Registered User
Default just cammed engine. now it is locked up
bare w me as im a little new to this. so i got a 6.0 from fb marketplace and engine span freely when purchased. i then proceeded to do a complete texas speed cam kit along w dual valve springs and ls7 lifters hardened pushrods new 10295 melling oil pump new retainer plate etc. i also installed a tbss intake w 50lb injectors. so this is where my problem starts, on friday we did the first start up on the engine w the stock 5.3 ecu that came in the truck (no tune) and everything ran good for about 15 seconds had 50 psi oil pressure when truck shut off. i assumed it was running rich because of the diffrent size injector and no tune but i then tried starting it up again but battery drained itself. i didnt have a jump box to jump batter to start up again. engine span freely by hand even after first start up but we didnt manage to find a way to jump it so we left the truck sitting for about 3 days. came back monday and now motor is completly seized and will not rotate. wondering what could have went wrong did everything according to spec and im at a lost for words. any help is appreciated thank you so much
Old Aug 1, 2022 | 06:21 PM
FFDP's Avatar
Did you pull the plugs yet and then try to spin it over?
Old Aug 2, 2022 | 06:02 AM
smokinlmm's Avatar
Maybe it hydro locked.
Old Aug 2, 2022 | 07:27 AM
1redta's Avatar
your going to need to tell us more, spin with plugs? water in oil, did you wash the cylinder walls with to much fuel, did you forget a wrench some where, did you…. List goes on
Old Aug 2, 2022 | 09:12 AM
TXsilverado's Avatar
this is where I would start. A hung injector could have filled a cylinder with fuel and hydrolocked the engine.
Old Aug 2, 2022 | 11:47 AM
smokinlmm's Avatar
Did you check the starter to make sure it didn't take a dump and the bendex get hung up.
benvortec
26
Jul 3, 2007 04:51 PM
9GMC9
Jan 19, 2006 06:36 PM
9GMC9
Jan 19, 2006 08:27 AM
jasond26
Mar 21, 2003 07:46 AM
