Intermittent Fuel Pump Problem
Old Dec 30, 2010 | 07:27 PM
  #31
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Havent swapped the FPR but did drive it around for over a 100 miles running errands with no problems at all...
I did score a 34" radiator with oil cooler for 75 bucks out of an 09 highway patrol tahoe and a stock catback for 50
Ordered a Blackbear two pin efan harness so my truck can finally have efans after all the other **** my truck has had on it, it has always rocked a clutch fan but soon that will be no more
Old Feb 12, 2011 | 10:41 PM
  #32
1slow01Z71's Avatar
Anybody got any suggestions, damn thing almost left me stranded tonight. had to use a wire I had in my toolbox to run power directly off the battery to the fuel pump prime circuit to get me home.
Old Feb 12, 2011 | 11:18 PM
  #33
fredkj3's Avatar
sounds like you have something going on in that fuse/relay panel.. can you take it out or apart?? there may be some burnt wires or burnt connections in there that you cant see from the top..
Old Feb 15, 2011 | 10:45 AM
  #34
CashDudeHomie's Avatar
Sounds like the wire that trips the fuel pump relay is bad. I feel your pain. I've had to replace a few electrical connectors in the past couple of years as they wear out.
Old Feb 15, 2011 | 07:20 PM
  #35
budhayes3's Avatar
PT's Slowest Truck
Sounds like you need to run a new wire or two Cody, unless you can find where the open circuit is...might be right at the connection in the fuse panel, especially if you've been in there before messing around
Old Feb 19, 2011 | 12:34 PM
  #36
1slow01Z71's Avatar
For anyone wondering what the problem was, it was the actual fuse box the part that the fuel pump relay plugs into. The pins of the fp relay werent making good contact, replaced the whole fuse box with a new one and the truck runs great.
Old Feb 19, 2011 | 12:37 PM
  #37
budhayes3's Avatar
PT's Slowest Truck
Cool deal Cody...were the terminals spread out and charred from arching? I've seen this before on the Toyotas and Lexi (plural for Lexus lol) that I've worked on through the years. I've had more than one Land Cruiser and LX470 where this happened to the EFI main relay. Usually the pins of the relay will show signs of arching, helping with the diagnosis
Old Feb 19, 2011 | 01:50 PM
  #38
1slow01Z71's Avatar
Yeah it was melted a little bit and the relay wiggled easy in the socket
Old Feb 19, 2011 | 03:15 PM
  #39
2004SSS's Avatar
dam sucks i didnt see this i had the same problem with my truck a long time ago from always pulling the relay as added security. one of the contacts in the relay had widend a bit and was interminute until i found that.
wish i could score a radiator for that price i need a new one with a trans cooler. wish ron davis would send me one too.
slowlsx
Aug 13, 2015 08:28 PM
roprisiu
Aug 9, 2015 10:47 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
