Intake Tube
I only want a tube for my Airaid intake. I don't want to have to buy a new setup (ie. UPD or K&N FIPK).
To you guys that have made your own intake tubes for 99+ Silverados, what did you use? Please be specific (especially with length and measurement) and pictures would help too. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
There's a guy on this forum that made an intake tube out of mandrel bent 4" exhaust tubing. There's another guy over on www.fullsizechevy.com/forum that made his out of black heavy duty 4" duct tubing. He says it's holding up good.
My problem is I can't find any tubing at my local hardware store that will work. Thanks in advance for any assistance with this matter. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Mine is made out of 4" PVC pipe. It took some time and several different hardware stores to locate exactly what I wanted. I ended up with a 4" 90* bend from the throttle body, then straight 4" tube about 20" I'd guess. MAF goes on that end. I put a round K&N filter on the end of the MAF. I used the rubber gaskets form the stock setup to connect the MAF and the throttle body.
Don't buy the thick PVC like from home depot. My tube is pretty thin - I can squeese it hard and it will flex some, the thick stuff wont do that. I had to buy about 4 feet, but it was cheap. I spent about $15 - $20 on the parts, plus about $55 for the filter. I have no complaints with it. I'm glad I saved $100+.
If you didn't want to make an intake tube you could probably call volant & tell them you bought a volant intake system used that didn't come with the tube & I bet they will sell you one for around $110. I had a spare volant intake tube that I didn't use but I have already given it to my brother to use on his suburbon.
AHelm3
Apr 8, 2016 07:51 AM
BlackGMC
Aug 17, 2015 07:07 PM
