Intake/Throttle body problem
Old Aug 22, 2005 | 09:37 AM
BLACKND's Avatar
Default Intake/Throttle body problem
I was switcing out my Ported TB back to my stocker this weekend. Was tightening the 3 nuts on the intake where the TB goes, and the top stud sheared and snapped. So now I am running with the TB held on by the 2 bottom bolts, It seems pretty tight and not running bad, at least not any worse than it has been, but I'm trying to figure out how to replace this. The stud doesn't go all the way through, I'm wondering if they are tap in studs that you can pull out and wedge another one in, or would I have to replace the entire intake?
Old Aug 22, 2005 | 10:11 AM
KLUG'S SS's Avatar
FormerVendor
The three studs are threaded into the intake. Did you break it off flush with the intake or is some of the stud sticking out where you could grab it with a pair of pliers or something and just turn it out.
Old Aug 22, 2005 | 11:25 AM
BLACKND's Avatar
Yeah, there is about a 1/2 inch of thread sticking out of the intake. I can definitely grab hold of it. It pretty much broke off flush with the lip on the TB unit. So where can I get another stud to thread into its place? The dealership?
Old Aug 22, 2005 | 12:18 PM
KLUG'S SS's Avatar
FormerVendor
Well at least you can grab ahold of it. Instead of the pliers you could always do the double nut trick on it. Thread two nuts onto the stud and tighten them back to back, this works pretty well for getting studs out also.
I would say that you will probably have to go to the dealership for the new stud.
Old Aug 22, 2005 | 01:08 PM
BLACKND's Avatar
Thanks for the help Klug. I'll try that and try to go by the dealership here just after work.
Old Aug 22, 2005 | 04:09 PM
KLUG'S SS's Avatar
FormerVendor
No problem, I had to remove the studs on my intake before and they came out pretty easily so you shouldn't have a problem.
Old Aug 22, 2005 | 07:28 PM
v8
17,16,15,14,13,12,11 Drvr
hey curtis i have a spare if you need one.
Old Aug 22, 2005 | 10:54 PM
storm5.3's Avatar
13 Second Truck Club
Lance gave me some regular bolts to put back in mine after I took off the TB spacer and they seem to be working...
Old Aug 23, 2005 | 01:09 AM
TXsilverado's Avatar
go to ace hardware for stuff like that. way cheaper than dealorship and im willing to bet that they have the exact bolt that you need.
Old Aug 23, 2005 | 08:29 AM
BLACKND's Avatar
Yeah, I found some yesterday. The dealership wanted 13 bucks each, I wanted to buy a few extras, just in case.
