Intake air temp sensor relocation
Old Feb 6, 2005 | 08:01 PM
L-EATER's Avatar
11 Second Truck Club
Default Intake air temp sensor relocation
A couple guys had wanted to see how I re-located the IAT to get an accurate reading on the temps after the blower. I just used an LT1 style sensor and mounted it in the EGR blockoff plate with a rubber grommet. Then I cut and extended the wires that went to the factory IAT which is part of the mass air flow sensor. Simple and it works great.
Attached Thumbnails Intake air temp sensor relocation-intercooler-006.jpg   Intake air temp sensor relocation-intercooler-007.jpg
Old Feb 6, 2005 | 10:43 PM
qwank's Avatar
good idea
Old Feb 7, 2005 | 02:32 PM
NateZ's Avatar
You have that hooked up to a gauge or how do you get the readings from it?
Nate
Old Feb 8, 2005 | 03:28 AM
L-EATER's Avatar
Nate-I have the factory sensor disconnected and this one is hooked to its wires. This way the sensor is reporting to the PCM the actual temp of the air going into the motor instead of the temp of the air going into the MAF. I read it using Atap.
Old Feb 8, 2005 | 09:11 AM
NateZ's Avatar
Does it make it easier to tune or anything like that, or is it just for observation?
Nate
Old Feb 8, 2005 | 09:21 AM
BigTex's Avatar
Tuning is better because the PCM sees that actual temps of the air entering the manifold after compression, not before like on the stock location. Since the PCM adjusts timing based on temps, the tune would be off with the stock location IAT. Air may enter at 60* but exit the whipple at 140*. It would be good for the PCM (and you) to know the real intake air temp.
You can buy an IAT service harness from GM to go along with that IAT sensor.
Old Feb 8, 2005 | 11:56 AM
Yellowsierra's Avatar
Does anybody have the part number for the Iat sensor. I think I'm going to do the same thing so I can see the before and after of the alky injection.
Old Feb 8, 2005 | 03:40 PM
NateZ's Avatar
So do you have to retune after installing it since the IAT's that the computer sees will be allot higher than before?
Nate
Old Feb 8, 2005 | 03:47 PM
BigTex's Avatar
No, your PCM is seeing the real temp. Along that logic, you should retune if you DONT relocate the IAT.
The goal is to have the PCM seeing the real temp of the air entering the manifold. Normally, the IAT on the MAF is very close to the temp entering the manifold. But when you throw a whipple compressor after the stock IAT sensor, the PCM isn't seeing the real temps. If you relocate the IAT after the compressor, your PCM does see real temps.
Got it?
Old Feb 8, 2005 | 04:51 PM
NateZ's Avatar
Yep i got it now.
What i was sayin is that since my pcm is tuned for the whipple and stock IAT location, i would have to retune after i moved the IAT.
Nate
