Installing timing cover
Old Jun 30, 2006 | 12:22 AM
CashDudeHomie's Avatar
Exclamation Installing timing cover
1. Can I reuse the old gasket?
2. Where all do I put the RTV sealant?
Cam install is almost finished
3. Is it safe to drive without a custom tune yet? 220/220/114LSA 6.0LQ4.
Thanks.
Old Jun 30, 2006 | 12:27 AM
99Silver6.0's Avatar
Thanks.
Follow the guide on LS1HowTo.com. RTV across the bottom. Do NOT tighten any bolts UNTIL you get the crank pulley on and tight. Let the pulley snout center the cover. If not done correct the seal will leak. Dont oil that seal either. YOu can reuse the gasket yes. Im sure its safe to drive. But I wouldnt get too crazy.
Old Jun 30, 2006 | 12:38 AM
Alright I printed the 27 page guide on LS1howto and everything was great, but I didn't notice any RTV when I removed the cover, so I just wanted to confirm this. Thanks for the reply Jared.
Old Jun 30, 2006 | 12:49 AM
No prob. Stock they dont have any RTV there. The pan gasket seals usually. Just suggested you put a bead there.
Old Jun 30, 2006 | 12:56 AM
Hey this is the last question. What color RTV do I need? I think I have some blue, but it may get too hot for that down by the oil pan. What do you think? BTW Thanks for answering all of my questions.
Old Jun 30, 2006 | 07:43 AM
SSlow 4.8's Avatar
Red or orange atv... i beleive orange is the best for heat applications.
i was able to reuse the stock gasket on mine (only had 65k on the truck when i did the cam swap)... did you reuse it?
Old Jun 30, 2006 | 08:04 AM
Rhino79's Avatar
9 Second Club
I always use Ultra Black on engines.
Old Jun 30, 2006 | 08:19 AM
nonnieselman's Avatar
yea i always use the ultra black also! on everything, even tractor motors.
Old Jun 30, 2006 | 10:29 AM
SSlow 4.8 I'm gonna reuse the gasket once I go pick up some black or orange RTV.
Thanks guys for all the input.
Old Jun 30, 2006 | 10:27 PM
SSlow 4.8's Avatar
oh i forgot about the ultra black... lol yes, use that
