installing cam ran into problems
Old Jun 5, 2004 | 12:05 AM
BigTex's Avatar
No problem. I reused both WP gaskets and front cover gasket. I didn't change any gasket or seal, although I did have them in case they were needed. If the gaskets aren't torn, use them again. On my old truck, the WP gaskets rubber material had deteriorated and fell apart during the install.
Old Jun 5, 2004 | 12:36 AM
mwalls54's Avatar
Need More N2O Mod
heck if i known that i would have had it done tonite. another question, what kind of mixture should i use in the radiator. i am going to use water wetter.
Old Jun 5, 2004 | 12:56 AM
GREGGO's Avatar
I'd just use the OEM spec on the mixture. Sorry I chimed in so late. But I was going to suggest sanding one of the tools down with some emry cloth. I made my own this way since my lifters would not stay up at all. Good ol' Mobil 1. As for the gaskets, I'm with Tex on that. I've pulled the front end of the motor twice and reused them and went racing both times after pulling it. No problems to this point.
Old Jun 5, 2004 | 01:25 AM
Flyer's Avatar
I did reuse my gaskets too. I only had 11k on the clock when I did it though.
I would have suggested the sanding bit ... but I sanded my *** off with 220 grit paper and ended up on the bench grinder to get them to fit in a test block.
Old Jun 5, 2004 | 01:27 AM
GREGGO's Avatar
LOL!!!! I started with a 4" grinder and a Tiger Paw sanding disk.
Old Jun 5, 2004 | 09:11 AM
one03sierra's Avatar
Formerly one92rs
Talking
im running the green stuff and have not had any problems at all.
Old Jun 6, 2004 | 04:47 PM
mwalls54's Avatar
Need More N2O Mod
well cam is in and running good. thanks again for the help guys
all_individual
Oct 10, 2015 10:09 PM
fastjweb
Aug 15, 2015 10:47 AM
steves86ta
Jul 28, 2015 10:21 AM
all_individual
Jul 13, 2015 11:01 AM
GreyChevy
Jul 7, 2015 08:57 PM
