Injector question.
Old Nov 26, 2008 | 09:29 PM
GMCDee's Avatar
Default Injector question.
I got these 42lb to replace my stock ones and they dont even come close to fitting any ideas on what i can do, The pig tails wont plug into them and they are way taller then the stock ones. Heres what im working with any help..
Old Nov 26, 2008 | 09:33 PM
RandomHero's Avatar
lol those are definitely not truck injectors, infact I have no idea what they are. It looks like an injector for a clown car ls1 build. Very colorful
Old Nov 26, 2008 | 09:36 PM
skyhighsami's Avatar
no title here
Are they not Ford injectors? Aren't some of their stuff color coded ie blue tops, green tops, etc?
Old Nov 26, 2008 | 09:39 PM
Truckshop's Avatar
ford 42lb green tops. to make them work you need need ev1 connectors and some flat washers to space up your fuel rail.
Old Nov 26, 2008 | 09:40 PM
dirt track racer 81's Avatar
those are 42lb ford lightning injectors.. they are 42lb are 43psi..they would be around 48lb injectors at 58 psi..to run that injectors you need an ls1 style intake...how much you want for them?
Old Nov 26, 2008 | 09:56 PM
GMCDee's Avatar
Thats odd Blownchevy must have boxed up the wrong ones.. I need the right injectors if you have any 42lbs ill trade you straight across if you need them. Let me know
kbracing96's Avatar
Yep, ford green tops, you can use them by changing the pigtails on your wires, or get a hold of whipple496 and he can probably hook you up with some plug and play adapters. That's what I used on my 60's. You will also need to make some 5/8" spacers and longer bolts for the fuel rails.
Old Nov 26, 2008 | 10:11 PM
i didnt even think about spacing them up..honestly.. you should use these..you can go to your local parts store and get the right plugins..just have to splice them in
Old Nov 26, 2008 | 10:12 PM
GMCDee's Avatar
Damn thought id make it through my first tear down and rebuild with no big hiccups guess i should have known better . Im tuned for 42's i cant run the stock ones can i it would run like chit.
Old Nov 27, 2008 | 01:41 PM
silveradol33's Avatar
So you guys are just getting the 3.8 pontiac pigtails or w/e?
