Injector help
Old Aug 21, 2017 | 07:52 PM
1967c10's Avatar
Default Injector help
Hello all. i know this info is out there already but i keep finding conflicting stories. I have a gen III 5.3 from a 2000 taho with turbo/heads/cam. I'm about to place an order for Siemens/Deka 80LB injectors. trying to figure out if they will fit under the stock fuel rails.
Will I need spacers?
Will I need a adapter for wiring?
If not can someone recommend an injector in the ~$400 price range to support 650-700 hp?
Thanks!
Old Aug 21, 2017 | 08:39 PM
madmann26's Avatar
Thanks!
I had a set under my stock FF rail. I had to have rail spacers. I got the ICT billet spacer kit.
However,
There isn't great data for them. In other words, they're a bastard and a half to tune. If you have good, reliable data then it's going to be easier.
They're really geared for Mustang's. That's where all the reliable data is.
Old Aug 22, 2017 | 09:49 PM
1967c10's Avatar
i had someone recomend the fast 60LB injectors. but i thought they are LS3 style which is way shorter than my truck injectors
Old Aug 23, 2017 | 11:50 PM
vidan27's Avatar
Deatschwerks 32D-00-0060-8. They flow 72lbs/hr. Direct drop in. Reworked stock injectors. Great data available.
Old Aug 31, 2017 | 05:13 PM
1967c10's Avatar
Sounds like a winning ticket right there
