Important Update From Flex-a-lite
Old Aug 27, 2004 | 04:39 PM
TigerFan187's Avatar
Default Important Update From Flex-a-lite
I saw this on another website and sorry I cant link it but Im sure someone can do so I just thought alot of you would need this info!-----
http://chevytruckworld.tenmagazines....?aid=709&sid=1
Flex-A-Lite having problems??????????????????????
Old Aug 27, 2004 | 04:47 PM
abbo7's Avatar
My pro-active stance is not to buy a product from them again. I am sure they make some good ones but I dont want to find out which ones.
Old Aug 27, 2004 | 05:20 PM
Damn That Bad?
Old Aug 27, 2004 | 08:53 PM
Dave N's Avatar
I had a FAL electric fan on my Toyota Tacoma and the fuse housing self-destructed just like that article said. One day I noticed that the fan wasn't running and popped the hood to find the fuse all melted. I'll have to say that Toyotas have an efficient cooling system, because I drove it for about two days without a fan in the summer before splicing in a new fuse, and the temp gauge never went over the normal mark.
The Toyota fan wasn't worth the money either. I paid over $100 more to get a "Toyota-specific" fan, and the only thing that made it different from their generic fan was four metal mounts (they were plastic in the generic fan). My fan always worked, but several other Tacoma owners had them fail from off-roading, beach running, etc. I know I'll never buy from FAL again.
Old Aug 27, 2004 | 09:08 PM
go with the Nelson fan harness, way cleaner install and works great
Old Aug 28, 2004 | 12:28 AM
GMC_DUDE's Avatar
Well, first my VSC went out. While replacing it with a DCC controller, I noticed the fuse had also partially melted. Not wanting to hassle with Flexalite, I shopped the local auto parts stores for a 40A replacement fuse holder, and could find none (is Someone trying to tell me something???). I ended up using a 40A PAL (?) fuse. It looks like a sugar cube with two large copper strips coming out. I bolted the wires to the strips via ring terminals, and enclosed the assembly in a plastic box from Radio Shack. So far, everything is working, but I'll keep my fingers crossed.
GMC_DUDE
Old Aug 28, 2004 | 06:18 AM
black_yukon's Avatar
I know some people have used 40 amp audio fuses and fuse holders
Old Aug 28, 2004 | 07:46 AM
12sec.5.3's Avatar
I'd like to know more about this.
Old Aug 28, 2004 | 01:37 PM
check out nelson's website www.nelsonperformance.com. You use pin 42 on your pcm to ground out the relays and they'll turn on your fans when the computer says so. 4 wire hook up to trigger the relays and then 4 wires for the fans. You would have to ask how you turn on the ground through pin 42 with edit though, I have a Wester's and he did it for me
Gerry
check out this link for a few pics of the harness and mounting
https://ls1tech.com/forums/showthread.php?t=203851
dsbodley
Nov 14, 2015 09:46 PM
gaps
Oct 15, 2015 02:53 PM
shootermwc
Oct 8, 2015 01:45 PM
dantheman1540
14
Sep 28, 2015 09:22 PM
