I'm Lost
Old Oct 18, 2007 | 04:42 PM
ZZebes's Avatar
Default I'm Lost
My buddy has a 1995 Sierra with a 305TBI and whenever he accelerates from a stop the motor makes backfiring sound and dies when he gets over 2000rpms, when he is moving and gets past 2000 it makes a backfiring noise constantly
what the hell is going on
Old Oct 18, 2007 | 05:12 PM
KySilverado's Avatar
cats stopped up
Old Oct 18, 2007 | 05:17 PM
Grumpy5.3's Avatar
Have you looked at the coil??? what have you done or checked!!!
Old Oct 18, 2007 | 05:20 PM
ZZebes's Avatar
cat is almost brand new factory replacement about 5000 miles ago
dist. is almost brand new
i'll check the coil later
Old Oct 18, 2007 | 05:42 PM
distributor cap cracked... ummm if it has one
Old Oct 18, 2007 | 06:21 PM
dirt track racer 81's Avatar
check all the ignition as is was gm's finest for ignition problems...could be out of time...pull the spout connector and check the timing should be set at 0 or 10..should say there by the radiator
mwalls54's Avatar
Need More N2O Mod
there is a sensor on the throttle body thats making it do this. i do not remember which one it was. I had this same problem on a 4.3 about 10 years ago and i just swapped throttle bodys and that took care of it.
Old Oct 18, 2007 | 06:22 PM
water temp sensor could be bad too
Old Oct 18, 2007 | 07:17 PM
andrew383's Avatar
traveling mod
i have a friend that had a prob like that, egr valve was sticking,replaced and fixed everything
Old Oct 19, 2007 | 08:25 AM
I believe it out of time terribly....or.....it's the Throttle Position Sensor on the TB. Check his timing though...first....because it sounds evactly like it's jumped time something terrible.
