IAC Problem Need Dynamite!
Old Nov 16, 2008 | 08:47 PM
M.Roberts's Avatar
Default IAC Problem Need Dynamite!
Does anyone know, if it were possible, to put a resistor inline to the IAC motor wiring? Or some way to physically de-sensitize it? There are 4 wires going to it, not much info in Chiltons book. My truck surges awful between 45-55 mph, done it since the cam swap, few years ago. When I unplug the IAC, it runs great at speed, just idles poorly. Why does the IAC even cycle when I'm driving it on the road? I had this thing tuned at MTI in Houston, too. THIS is driving me nuts!
Old Nov 16, 2008 | 08:57 PM
dirt track racer 81's Avatar
DozerDan can get you some dynomite
Old Nov 16, 2008 | 09:51 PM
budhayes3's Avatar
PT's Slowest Truck
Don't hack up the wiring and try to desensitize the IAC, there's something in the tuning that needs to be ironed out...
Old Nov 16, 2008 | 09:57 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I would also say it's most likely something overlooked in the tune. Unless the IAC motor is bad???
Old Nov 16, 2008 | 10:15 PM
M.Roberts's Avatar
well, I swapped it out a couple of times, and its always the same. Checked and cleaned it more than once to be sure. IF it almost does perfect with it unplugged, I figured if I could calm it down somehow by altering the amount of voltage it gets I might could smooth it out where I could live with it. I run a predator custom tune on it now not much I can do with it. Just trying to find an economical solution.
Thanks for the help
How much does Dozer Dan charge for a stick?
Old Nov 16, 2008 | 10:25 PM
its more than likely in the tune. have you logged the iac to see if its jumping around alot? something you see in bigger cams is a lean surge that can cause bucking at light throttle loads, but just since you have a small cam i wouldnt rule that out because it could be a tune problem
Old Nov 16, 2008 | 10:30 PM
M.Roberts's Avatar
I dont have anything to monitor the program with to know what its doing. I wish I did.
Old Nov 16, 2008 | 10:42 PM
dewmanshu's Avatar
Moderately Differentiated
I can't imagine that 206/212 cam causing too many issues. What's the LSA on it? Unfortunately, having the predator, you are kind of held hostage. The tune needs to be adjusted. Running a resistor in theory would work to some degree today. Maybe not in the spring time or summer, but your idea on the surface makes sense to me. If you have no economical way to adjust the tune, PM Torque_Wrench and ask him what wires do what on the IAC (tell him dewmanshu said he said he would give that info up). Which ever the one is the control voltage, fug it, buy a bag of resistors at Radio Shack and start experimenting.
Old Nov 17, 2008 | 10:25 PM
M.Roberts's Avatar
EVERYONE thanks for the input
Dewmanshu, I pm'd Torque_Wrench to see if he'd know, and if I can decipher the wiring, Im gonna go for it... Even thought about a rheostat mounted somewhere inside the cab, or a switch, some way to disable the IAC when I am driving like on longer trips, and turn it back on when I need it. Hmmm I think the cam is 112??? lsa , not sure its been a while.
Old Nov 23, 2008 | 02:33 PM
M.Roberts's Avatar
Surely somebody knows about this???
