Originally Posted by Naked AV
:thumb:
This is prescription for your problem right here. :stupid: |
Originally Posted by zippy
i knew what you meant by it, but wanted to clarify it for others that may have taken it the wrong way.
Philip S. |
Mine gave me 15 RWHP all over, 20 RWHP peak, on back-to-back dyno runs, with the cam being the only variable changed. This is the same cam.
Best part of the cam install was the off-idle power....'holy shit' :eek: is the best way to describe my reaction. I am very happy with it. |
Stock torque converter? If so, none of the above. Get a Cam Motion 205/212 high-lift cam like the one in my sig. :D
Alternatively, there is a GM part number (12574519) with almost the same specs, and costing around $250: 204/211, .520/.520, 116 Would this cam be good for my 5.3L? Where can i get a cam motion cam? Also the alternative GM cam, would that be a good stealthy cam that will make decent power? |
Im in the same boat as Suddog. Would the Comp 206/212 .551/.522 112 cam and a trailblazer verter be a good combo?
the 206/212 cam doesn't need a verter to the best of my knowledge. But It would help you take off a bit faster.
www.cammotion.com is where I found the info on their cams. :drive: |
Ok guys I went with Kim Allens' Cam Motion Camshaft. Now comes the hard part...putting it in. Anyone know of someone trying to get rid of a set of LS6 or 918 springs?
Damn, I should have checked this yesterday, I have something I think you would have liked. I had the 206/212 on a 112lsa with +4*. Anyway, I think a tb stall would really help it. my times went down with the cam a little, but my MPH went up a good bit. Anyone else looking for a similar performance cam pm me. :cheers:
How much compression does the 4.8L have? 9.0 to 1? Thats probably whats killing the torque, not enough compression. Should be 10.7 to 1 like the z06.
