I think that I have the highest IATs
Old Aug 5, 2005 | 04:24 PM
MikeGyver's Avatar
Default I think that I have the highest IATs
With a 6.0 running 6 lbs boost. I relocated the IAT sensor into the manifold. The bypass for the Whipple is wired shut. The first thing I checked when my HP Tuners came in was my IAT. Oh, yeah, it has a Nelson tune with 42 lb. injectors, no Whipple electronics (never worked). I start the log, then start the truck. IAT 91°, same as outside. After about 15min around town, 35mph, Temp. at 171°. I go out on the highway, cruising at 65, very slight uphill. 205°, quits climbing. I have the alcohol set to start spraying at 2 psi just for this log. Next, I accelerate just enough to keep it above 2 psi for as long as possible. Temperature drops, then holds at about 170°, just for my info to know that the alcohol works if I raise boost in the future... 205° cruising?! With a 6 psi setup? I thought Whipple sold this to me because screw compressors don't heat the air as much. As much as what, a furnace? Do I get the IAT record?
Old Aug 5, 2005 | 04:35 PM
desTRUCKtive's Avatar
Well I think that by the way that you have described your temps. I think that you have just invented a new method to roast a turkey. By the looks of it, you can have one cooked in a matter of 15 minutes. I have seen 195. but this does seems kind of high.
Old Aug 5, 2005 | 04:54 PM
03sierraslt's Avatar
I am running a Kenne Bell on a 6.0 @ 6.5-7psi and have never seen temp that high even in 94 degree weather.
Old Aug 5, 2005 | 04:55 PM
The highest that I have seen is 174 at the end of a 1-3rd wide open run. At Right after the wide open run they were back at 135 or so within about 2min.
Old Aug 5, 2005 | 05:31 PM
454SuperSport's Avatar
What are you talking about when you say the whipple bypass is wired shut? that could have something to do with it.
Old Aug 5, 2005 | 05:57 PM
MikeGyver's Avatar
I have it safety-wired so that it can't bypass, because (A), the Whipple computer was always opening the bypass under boost conditions when nothing was wrong, and (B), I don't know how to control it with the Whipple computer, since the Whipple computer is in a box somewhere in my garage. Is there some other way to operate it?
Old Aug 5, 2005 | 06:10 PM
MikeGyver's Avatar
I never thought to do a search on what I just asked. I searched and found my answer. I'll bet a lot of people that get criticized for not searching also think that their problem or idea is unique.
Old Aug 5, 2005 | 06:40 PM
kbracing96's Avatar
You supercharger guys and your intake temps are just NUTS . I didn't have a way to check the temps on the turbo before I put the intercooler on, but now with an OBX, ebay cooler, I have never seen over 135*, and that was just sitting in traffic on a mid 90's day. I start to go and they cool right off. Going down the high way, running the **** out of it at 7 psi it usually only 15* over ambient. Even when I turned up the boost to 10-12 psi, it was 80* outside and made 2 back to back, 0-105mph runs and never saw more then 102* on the gauge. But the 160-180, even 200* never even come close. Must have something to do with these gutter sucker turbos .
Old Aug 5, 2005 | 06:59 PM
I see about 140* at about 5psi with my foot in it. Thats straight from the turbo, no IC or anything. The charge pipe runs along side the exhaust pipe too.
Old Aug 5, 2005 | 07:25 PM
krambo's Avatar
I see a constant 95 - 115 crusing in 85* heat at 55 - 65mph. After a 1/4 run I see no higher than 150* in 85* ambient. Magnacharger Radix 2.9" pulley on a LQ9 cammed.
