I ordered my STUFF!!!
OK, wow, this is exciting! Here's what I ordered!1.TCI 4L60E Super Street Fighter Torque Converter, 3500 Stall Speed, 2.5:1 STR, See that STR and stall!!
2.ARP Torque Converter Bolts - M10 x 1.5 Threads, GM 200 & 700, 4L60 & 4L80, 6 Piece, Truck because the stockers will strip when I remove them.
3. B&M Supercooler Transmission Cooler, 24000 GVW, 11" x 6" x 1-1/2" , for the verter
4. Thunder racing cam. 224/224 duration @.050 with .563/.563 lift on a 112 LSA!!! Lump Lump Lump in my 293ci!! It's barely going to idle!
5.Taylor "409" Pro Race Wires, 1999-2005 GM 4.8L, 5.3L, 6.0L Trucks - Black
6. NGK TR55 Spark Plugs, Stock heat range, gapped at .050
7. Gasket package.
I still need to get an LS2 timing chain, longer balancer bolt, maybe a new oil pump and an oil pump pick up tube o-ring plus a Cut-out too!
BRING IT BABY!!
Philip S.
Originally Posted by Seeing Red Again
Wow!
You are going to be putting some big rev's on the little 4.8! BTW, what are your plans for traction? Going with a LSD and gears?
Philip S.
