I need some help???
Hello guys, I have a 2004 Chevy truck 5.3. Last night i was driving on the freeway going home, and my truck turned off out of nowhere. I had my friend tow me home. I tried to turn it on, it struggled to stay on, and then it died. I check to see if it has fuel, and it has fuel. Then I check to see if it has a spark and its working properly. Then i checked to see if the fuel pump is turning on, and it is. I was already late so I disconnected the battery and then the next morning I tried to turn it on and it turned on but then after it got warm it started to act up again and the check engine soon and ABS lights turned on???
Has anyone ever had this problem?
Can anyone help me out??
did a code flash in the message box when it happened? i forget what it said but i had a 2002 tahoe flash a code in the message box and it would barely run....come to find out it was in what the dealership called "limp in mode", a program the computer defaulted to....turned out to be a faulty tps switch.....
