i need help
Old Nov 1, 2011 | 12:40 PM
WICK3DxGATA's Avatar
Default i need help
okay so i have finally decided on which cam im going with and its the HT1 SDPC.
here is a link to it: http://sdparts.com/details/scoggin-d...er/cc54-st1-11
so i need to know what else i need to order before i order it so i can just do it all at the same time?
ive been told to get new springs and rods but which ones?
and if there is anything else you guys would recommend it would be a big help.
Old Nov 1, 2011 | 12:50 PM
i guess i should mention my truck is a 99 5.3l 4x4 with around 170000 miles. it has just a air intake and true dual exhaust with a tune from wheatley right now. i will also be putting some long tubes on it very soon also. When i put the cam in i will be completely taking apart the engine and cleaning and replacing any parts that need to be replaced.
Old Nov 1, 2011 | 01:05 PM
grey matter 04's Avatar
13 Second Truck Club
LS6 valve springs will work they like $60
hardened 7.4 pushrods from maker of your choice about$110
timing cover and water pump gaskets to be safe
Old Nov 1, 2011 | 02:37 PM
Fastcount03's Avatar
At 170K miles I would definitely replace the lifters, get the LS7 lifters:
GM Performance Parts 12499225 - Lifter Kit, Gen III Engines, Set of 16 | SDParts - 1-800-456-0211
Valve springs:
GM Performance Parts 12499224 - Valve Spring Set, GM LS2, LS3, LS6, Set of 16 | SDParts - 1-800-456-0211
Push rods:
Manley Performance Parts 25735 - 7.400 Stock Length LS1 Manley Pushrods | SDParts - 1-800-456-0211
and then the LS2 HD timing set. Look in the classifieds.
Old Jan 7, 2012 | 10:59 AM
so i think i finally decided on everything that i am going to get and gather all the money. but can yall tell me if there is anything else that i will need.
HT1 cam
Scoggin Dickey Parts Center CC54-ST1-11 - HT1 SDPC LSX Truck Cam 214/218 .559/.562 111 | SDParts - 1-800-456-0211
ls7 lifters
valve springs
7.400 push rods
ls2 hd timing chain
GM Factory Replacement Parts 12586482 - GM Performance Parts HD Timing Chain | SDParts - 1-800-456-0211
so if there is anything else that yall can think of it would be really help full before i order it.
Old Jan 8, 2012 | 10:23 AM
devink's Avatar
I think you need slightly shorter pushrods with ls7 lifters. I coild be wrong though, can anyone confirm this?
