I Need Help
Old Jan 1, 2004 | 08:20 PM
Default I Need Help
Got in the truck last night about 6:00 and put it in drive Felt slugesh and then it started to Whine like the fan clutch was Stuck i pulled over killed the motor...looked at the Tran Fluid it Was fine...so i started it up truck was fine Still seemed slugesh...Got in About 2 hours later and when i put it in Reverse it started to surge BAD....put in drive it was fine......I need help i looked over the whole truck and i find nothing...drove it today and it was fine but its making a clank at stop lights..Sorry for the long theard but if any one will know it would be yall......Thanx
Old Jan 1, 2004 | 08:32 PM
You said that you killed the motor to check tranny fluid,can't do that,motor must be running and hot to check fluid.
Old Jan 1, 2004 | 08:39 PM
Sorry...When i started it back up i Checked the Fluid and took it Around the block and it was fine...Before i left....I wanted to make sure i wasnt going to be Stranded on New year eve......
