I just bought a 6.0 short block!
Old Aug 2, 2011 | 02:15 PM
axekick's Avatar
Default I just bought a 6.0 short block!
I have to go pick it up since it's in Houston and I'm in Austin. I don't have much money so this will be a slow project but I'll need to get it freshened up. I'd like to get the block machined and put new rings, bearings and rod bolts in. I'll probably pick up some 317s since they're cheap and use my cam and springs and whatever else I can from my current engine. I'd love to get some advice and tips from you guys as I do this, but first of all, does anyone have any recommendations for a machine shop in or around Austin?
Old Aug 2, 2011 | 08:38 PM
mitchellmade's Avatar
MASS seller approved
Lq4 or 9?
Old Aug 3, 2011 | 08:26 AM
axekick's Avatar
I'm sure its an LQ4 although I haven't seen it yet. I went to a local machine shop and it sounds like it will be around $500 for machine work and bearings. Has anyone ever heard of Performance Machine in Hutto? I'm pretty sure I'd rather use them than Quality Engine Exchange but I'd like to hear other Austinites experience.
Old Aug 3, 2011 | 08:31 AM
axekick's Avatar
Of course if I ran across a cheap set of flat tops out of an LQ9 I might pick them up. Then I could run unmilled 317s. Or I could skip the pistons and use the money toward a set of 243's. I wish I could use my 706s but the work it would require would cost so much that its not worth it.
noproblems209
Aug 10, 2015 06:57 PM
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
steves86ta
Jul 28, 2015 10:21 AM
Gadgetized
Jul 22, 2015 11:55 AM
