I have a ???
Old Oct 29, 2006 | 01:28 AM
Daryl4.8's Avatar
Default I have a ???
This is a cam that i found spec r Duration is 216/224 RPM range is 1500 to 6000 will this work on a 4.8 with 918 springs
Old Oct 29, 2006 | 11:29 AM
xchevyx24's Avatar
yes it will work but i dont know how good.
Old Oct 29, 2006 | 01:29 PM
it will work but you are going to have to do some good tuning on it. whats the LSA?
Old Oct 29, 2006 | 07:56 PM
Daryl4.8's Avatar
I think the LSA is 112 or a 114
Old Oct 29, 2006 | 08:11 PM
Daryl4.8's Avatar
What is the differents from a 112 LSA AND 114 I dont know
Old Oct 29, 2006 | 09:06 PM
Varying Lobe Separation Angle.....................................
...............Tighten............................ ..............Widen
Moves Torque to Lower RPM..............Raise Torque to Higher RPM
Increases Maximum Torque................Reduces Maximum Torque
Narrow Powerband...........................Broadens Power Band
Builds Higher Cylinder Pressure............Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock........Decrease Chance of Engine Knock
Increase Cranking Compression...........Decrease Cranking Compression
Increase Efective Compression...........Decrease Efective Compression
Idle Vacuum is Reduced....................Idle Vacuum is Increased
Idle Quality Suffers..........................Idle Quality Improves
Open Valve-Overlap Increases...........Open Valve-Overlap Decreases
Closed Valve-Overlap Increases.........Closed Valve-Overlap Decreases
Natural EGR Efect Increases..............Natural EGR Efect is Reduced
Decreases Piston-to-Valve Clerance....Increases Piston-to-Valve Clerance
