I blew it...
Old Dec 23, 2004 | 12:25 AM
BlownChevy's Avatar
blownerator
25 Year Member
Some of the early trucks needed to be ground....
The newer trucks are good to go....That means you Grippy, get that damn thing installed.
Congrats on the install Tex....good to hear there is another blownSS in the world!
Old Dec 23, 2004 | 12:30 AM
moregrip's Avatar
what a rush!
Blown, had a few set backs today, didn't do a whole lot, if anything.
btw, Congrats Big Tex! Which pulley you running?
Old Dec 23, 2004 | 12:48 AM
BigTex's Avatar
I'll be happy to log before and after intercooler temps. Even without the cooler, it held 16.5* timing (I had 17 in the table) through a full 2nd gear blast with no knock retard until 6000 rpms where it was pretty lean. O2s were right on .900 until the MAF maxxed out, then they went slowly down hill. I made another tune this evening and will test it tomorrow.
I'm running a 3" pulley right now. I've got a 2.75, but I'll rarely run that one.
Old Dec 23, 2004 | 05:01 AM
sfj
forget the before and after intercooler i want the before and after the install as well kinda give us a step by step what HP your getting off of it all
Old Dec 23, 2004 | 08:19 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Spray it!
Old Dec 23, 2004 | 08:22 AM
Scream's Avatar
MOOBIES Moderator
Congrats Richard!
Old Dec 23, 2004 | 08:34 AM
BigTex's Avatar
Originally Posted by Neil 6.0
Spray it!
Don't think it hasn't crossed my mind.
Old Dec 23, 2004 | 08:38 AM
JERRY2500's Avatar
14 Second Truck Club
Sweet... Another fast truck.
Old Dec 23, 2004 | 11:10 AM
Flyer's Avatar
I think my bracket had to be ground on a little too. I don't remember exactly where, but I knew to look for it when putting it on and took care of it.
Old Dec 23, 2004 | 11:56 AM
BigTex's Avatar
OK, swapped the IAT harness this morning. Before the swap, my IATs were about 3-5* above my mirror temp display. Its was 27* outside this morning. After the swap, My IATs leveled out at 122*. They might have fallen more if I have been cruising on the freeway. I did a 2nd gear run for 6 seconds. IATs went from 122 to 147 when I let off. They continued to climb to a peak of 156* 6 seconds after I let off. IATs fell about 2-3* every 10 seconds after that , then down to 133* 1 minute after the WOT run. I'm sure the cold outside temps kept the IATs from going through the roof.
Even with the high IATs, I was getting 18* timing and only had a single instance of 3* knock. Still need to add more fuel. It was pulling hard at 6400 rpms.
