How much lift?
Old Jun 26, 2011 | 09:22 PM
kr1s's Avatar
Default How much lift?
How much lift can stock heads take?
I wanna do the tsp220 cam
What rockers,lifters,pushrods would you recommend?
5.3
Old Jun 26, 2011 | 09:58 PM
06murder's Avatar
u dont need rockers there buddy....what motor?
Old Jun 26, 2011 | 10:22 PM
kr1s's Avatar
woops, 5.3 lm7
Old Jun 26, 2011 | 10:45 PM
06murder's Avatar
nothing more then 230....imo tsp 220 one of the best dd cams , good tune it will make good power....but u just need camm push rods n duel springs n the gaskets...
Old Jun 27, 2011 | 12:05 AM
Nuclear Endless's Avatar
Springs n pushrods will take care of most cams you throw at it.
Old Jun 27, 2011 | 12:08 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
To best answer your question, it would help to know which heads you have.
Old Jun 27, 2011 | 03:02 AM
kr1s's Avatar
Lol stock heads? i don't know the casting numbers cause i don't have the motor yet, but this is the cam i was planning on ordering
Old Jun 27, 2011 | 04:38 PM
I misunderstood your question anyways. The TSP220 will work for you without clearance problems.
Old Jul 1, 2011 | 03:14 AM
kr1s's Avatar
Even though its a .581/.581
Old Jul 1, 2011 | 08:18 AM
dmelvin's Avatar
As long as you don't time it wrong like I did the first time (I don't wanna talk about it ) you'll be fine, luckily the cam I picked out had a low enough lift that even being about 90* advanced I didn't have a piston to valve event.
If you're running stock heads, you'll want some hardened 7.400 PR's, I'd get some behive springs rated to .600 lift, or if you want, you can grab some dual springs rated to .650 lift, if you do decide to change heads or pull them off and work them, I'd get new LS7 lifters and lifter trays, if not, don't worry about it.
You can reuse the stock rocker arms, I reused mine when I did my cam swap at 154,000 miles.
How close are you to getting your motor? I'm gonna be honest, it's kinda fun to see someone so excited about their first engine "build"/swap, and they're not afraid to ask the questions they need to ask and are able to take the answers without thinking they already know more than everyone else.
I'll be waiting for the build thread.
