How is dynamic cylinder air calculated?
Old Mar 10, 2005 | 07:10 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default How is dynamic cylinder air calculated?
When I was logging data on the other neat thing (DTC 1515) I discovered today, I also noticed I was running 43.5* of timing at 15.09 (stock map)... Guess I've been dodging the blown brand new 408 bullet for a couple of days...
So I looked a little deeper... When I start getting into it, my dynamic cylinder air plummets to 0.01 g/cyl (effectively 0) and the airflow plumets to at least 50% of what it was before. When I come off the throttle, it returns to normal. All of this with no codes...
Any ideas?
Could replacing a ground strap on the passenger side with 14 gauge wire and putting both straps to a header bolt instead of the back of the block locations be the root of this or do i have some weird intermittent short somewhere?
Old Mar 10, 2005 | 07:43 PM
SnakeOiler's Avatar
I would think that sounds like Torque Management kicking in. Do you still have TM in place? If so, remove it and re-log your same scenario and see what the data looks like then.
of course, I could just be smoking crack
Old Mar 10, 2005 | 07:59 PM
I AM A MOTHERF*CKER
TM would be pulling spark. That is, if I had allowed it to live
Vortec350ss
Jan 12, 2016 10:36 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
