How Does My Crank Pulley Look?
Old Dec 13, 2010 | 03:47 PM
smokin 2 stroke's Avatar
Default How Does My Crank Pulley Look?
does my pulley apprear to be seated all the way? i dont think it is, but the pulley isnt moving any more.
Old Dec 13, 2010 | 03:49 PM
dirt track racer 81's Avatar
what did you use to pull it on with?
Old Dec 13, 2010 | 04:11 PM
fastrt's Avatar
11 Second Truck Club
not there yet. you need a pulley installer. from^^^^
Old Dec 13, 2010 | 04:19 PM
skeet's Avatar
if you clean the shaft and clean the bore of the crank pulley and add some graphite, you shouldnt have any problems seating the pulley properly, i use my impact to run the pulley up, first i get it started, i set the impack to the lowest setting, then gradually increase torque and the pulley is going on, i do it numerous times without issues
hows the belt line up to the other pulleys? thats one way of verifing if the pulley is all the way on
Old Dec 13, 2010 | 04:23 PM
i used a 1inch longer bolt, then swapped to the factory bolt..its not moving the pulley any farther.
Old Dec 13, 2010 | 04:27 PM
Is the pulley stopping or is the bolt screwed up and not wanting to turn anymore? Some people have no problem using that method and I myself used it several times until I screwed up the threads in the crank and trashed a crankshaft. Ever since then I've used an install tool and never had a problem.
Old Dec 13, 2010 | 04:42 PM
well, long story short, long bolt bottomed out, chewed threads, ran tap through the the threads cleaned it up ..and now it just gets really tight and wont turn.
Old Dec 13, 2010 | 05:20 PM
Does the bolt screw out easy or is it slow coming out with an impact?
Old Dec 13, 2010 | 05:38 PM
fredkj3's Avatar
owe man this isnt good... i usually clean it really well and put some never seize on it.. tap it lightly until you can reach it with a longer bolt.. then install new bolt....
Old Dec 13, 2010 | 06:50 PM
i got it..i didnt run the tap down far enough..cleaned up the threads..and put the pulley in the oven at 400 for 15 min..it slid right on with my hands. i highly recommend heating up the pulley. now i just gotta take for my computer to get and my cam swap will be complete.
