How do you raise the idle ??
after my exhaust and intake were installed the idle dropped from 750rpm to about 550rpm idle and 500rpm in drive....is there a way to *correctly* raise the idle ??
I also read about the "plugs" for the throttle blade air hole for '99-'00 trucks to correct the idle flucuation....would this correct my problem or only make it worse ??, could I "test" this by putting a piece of tape over the air hole at idle ??
