how can i manually open injectors for cleaning?
Old Aug 16, 2010 | 11:48 AM
brandon_6667's Avatar
Default how can i manually open injectors for cleaning?
I am in the process of doing my lq9 swap and i'm getting ready to put the injectors back in but want to clean them out first. I saw somewhere where this guy had made a little tool to hook one end up to his battery and the other end was wired into an extra injector plug with a push button for manually opening and closing the injector so you can open/close it rapidly while spraying cleaner through it.
Anyone have and experience with this? he said it works for most injectors but i should check to see if i need to use a resistor or anything to control the current to prevent burning the injector out by overpowering it. Should i be fine with just connecting straight to the battery as long as i dont hold power to the injector for more than a second or so each time? just want a way to get it to open so the cleaner can flow through just like the gas does.
Old Aug 16, 2010 | 07:01 PM
quicksilverado's Avatar
You can use a 9 volt battery and it works great.
Old Aug 17, 2010 | 02:16 PM
Cool, thats the type of answer i was hoping for. what would you recommend for cleaning? i was going to use seafoam or some b12 chemtool if i can find it..
Old Aug 17, 2010 | 02:20 PM
BlackGMC's Avatar
Resident Retard
so, you just connect the injector for a second, while spraying cleaner? Do you do this a few times?
Old Aug 17, 2010 | 03:59 PM
I used some carb cleaner and then some compressed air.
Old Sep 9, 2010 | 02:09 PM
I ended up using a 9v battery and a momentary push button switch to clean them, worked great!
Corvette454l88
Sep 1, 2016 01:24 AM
MikeGyver
Aug 9, 2015 07:18 AM
BigEd_72455
Aug 7, 2015 11:36 PM
GM1697
Jul 9, 2015 01:55 PM
