How to build an exhaust resonator tube to eliminate drone
#32
Keep in mind the speed of sound will be higher inside the exhaust. 343 m/s is for sea level standard day conditions. The exhaust gases are much hotter and a mixture of air/fuel is present. The resonator tube is not passing exhaust however, so the temperature of the air inside it will not be as hot as the exhaust flow. I would use a value more around 400 m/s.
#36
now i'm just wondering...some people say you go 180 and point the resonator towards the engine.what is the difference?? and yes does it make a difference to do it before or after the muffler?
Last edited by three8threestker; Jul 27, 2014 at 08:56 AM. Reason: forget a question
#39
I've noticed that the drone occurs at different rpms depending on my trucks temperature. For instance when I first start it up and drive it, I hear the drone right at 1500 rpm. By the time I get home it's droning closer to 1800-2000 rpm.
My question for those of you that have built these tubes is how much of an rpm range is covered by one particular length? If I target the 1500 rpm drone my tube length is something like 32", if I target the droning at 2000 rpm it is 26"...How crucial is the exact length? Thanks for any input!
#40
