How big of valves in a 5.3?
Old Oct 19, 2013 | 11:27 AM
batboy's Avatar
11 Second Club
Default How big of valves in a 5.3?
I have an extra pair of ported 243 heads with a burnt valve (on my GTO before I got the Trick Flow 215 heads). I was thinking about rebuilding and selling them since they have 2.02 intake valves. I assumed they were too big to fit in the 5.3 or at least would cause valve shrouding issues. I'm starting to see other people using 243 heads with this valve size.
First, I'd like to confirm a 243 head with 2.02 valve would fit with no interference and second how much performance it'll gain me. Hopefully people that have actually done this will chime in.
They have excellent flow numbers (ported by PM-FL) and are currently milled to 62cc, but I could easily mill them a bit more when I replace the valve and have the heads freshened up. They also currently have low mileage Patriot Gold dual springs with titanium retainers.
Been thinking of doing a cam swap. If these heads will work good, might as well do everything at once.
Old Oct 19, 2013 | 12:01 PM
batboy's Avatar
11 Second Club
Been reading past threads and found several posts that say they used 2.02 intake valves in 5.3 motors. Found a number of posts that stated the larger valves cause shrouding. Even found a photo showing someone measuring heads with 2.02 valves using digital calipers which indicated about .030" of clearance with the cylinder wall.
Then I found this post:
Originally Posted by joshua022
I have 2.04 and a 1.575 in my heads!
Old Oct 20, 2013 | 01:55 PM
terravast4's Avatar
my PRC heads have 2.02 valves
Old Oct 20, 2013 | 06:33 PM
Blackpanther99's Avatar
2.02 valves is what I would do.
blownss27
Oct 27, 2015 11:42 AM
Jake99
Aug 8, 2015 07:56 AM
steves86ta
Jul 28, 2015 10:21 AM
low2001gmc
Jul 23, 2015 05:10 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
