how big can i go????
Old Nov 20, 2009 | 04:56 PM
slowswb's Avatar
Default how big can i go????
this is what i want to ask because i cant find a answer anywhere i was wondering how big of a cam can i go before changing injector or a fuel pump. i was looking at buying the thunder racing cam the tr220 but just dont know what to do... because i drive this truck year round but i dont want to nasty of cam. please i ask for info and as much as possible.
Old Nov 20, 2009 | 05:07 PM
00ChevyScott's Avatar
Wearin' da big hat
You're going to have to replace valve springs with any cam you swap in, so whats the big problem with doing injectors too? They're easier than valve springs.
Also what other mods do you have, what motor, what color is the truck, is it a regular cab, is it even a chevy?
You gave us no info at all about your truck
Old Nov 20, 2009 | 05:15 PM
slowswb's Avatar
yeah i got the valve springs already. see this is the thing im trying to piece together this truck on low fund and broke man parts.
Old Nov 20, 2009 | 05:16 PM
Wearin' da big hat
Still no info on truck...
Old Nov 20, 2009 | 05:17 PM
slowswb's Avatar
its 5.3 stock now got i have a 4.10 gear and long tubes and 3200 conveter for it.
Old Nov 20, 2009 | 05:18 PM
Wearin' da big hat
TR220 should be fine then. Who's tuning it?
Old Nov 20, 2009 | 05:19 PM
slowswb's Avatar
this is what im asking is the stock injectors going to flow enough?
Old Nov 20, 2009 | 05:21 PM
Wearin' da big hat
It will be close. I bet it will be in the 9x% range depending on the tune
Old Nov 20, 2009 | 05:24 PM
slowswb's Avatar
now this is the thing i want to spray it a 150 shot.. injectors or pump.
Old Nov 20, 2009 | 05:25 PM
Wearin' da big hat
Spray a 150 wet shot and don't worry about it. Stock fuel pump will be fine, injectors will be close.
