Holley 90mm throttle body
Old Nov 12, 2006 | 10:58 PM
Default Holley 90mm throttle body
I am planning to get the Holley 90mm throttle body. I would like this to replace my current 75mm cable throttle body, can anyone tell me if the existing IAC and TPS sensor can be transferred over to the Holly TB. Please advise.
Old Nov 12, 2006 | 11:26 PM
They probably use earlier Camaro sensors like mine.I use a UMIracing throttle body with an eliptical opening,it's part throttle response compared to my previous FAST 90 throttle body is much better.I haven't seen or used the Holley throttle body,but I have had very good results with the UMIracing unit.
Old Nov 12, 2006 | 11:30 PM
Were you able to transfer your existing IAC and TPS over to the UMI or did you have to rewire a new IAC/TPS?
Old Nov 12, 2006 | 11:40 PM
I had to change to a early Camaro TPS and I changed from a TBW setup to a cable,so I had to add a IAC sensor.I'm not really sure what the stock truck sensors look like.
blownss27
Aug 14, 2020 08:27 AM
murderedSS
27
Oct 12, 2015 11:13 AM
99bluefirebird
Sep 17, 2015 08:05 PM
chvy=power
Sep 8, 2015 11:06 AM
bisqikss
Sep 8, 2015 03:35 AM
