high flow oil pump
Old May 5, 2006 | 03:02 PM
Default high flow oil pump
Is it worth the cost of a high flow oil pump? I was reading an article and I think they just put a spacer in the spring and that was good enough.
Old May 7, 2006 | 09:13 AM
Quik's Avatar
5 year bitches!
all you need is a blue spring for the pump. the difference in a standard pump and ls6 one is the spring. i know cause i port and sell them
Old May 7, 2006 | 04:21 PM
closet red neck's Avatar
Where can I get the spring??? Or do I have to buy one from you!!!LOL!!
James
Old May 7, 2006 | 05:49 PM
99Silver6.0's Avatar
Cant you buy the shims to put in there too besides the spring??
Old May 7, 2006 | 05:55 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yes you can buy the shim also but why not go to homedepot and buy a little chunk of metal and put it in there use a dremel tool and port the intake and exit of the pump yourself would take all of 30min to do and clean.
GXPJAY
Feb 13, 2022 08:15 AM
JordanH
Aug 8, 2015 07:59 PM
BIGD4504
Jul 28, 2015 11:46 AM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
