Hey Guys
I have a 2003 ext cab silverado came w/4.8 and now sports a 6.0 stock
now i had a bad tranny and i was racing a guy in a old school mero and the trans flared up when going to 2nd to 3rd and the 6.0 bounced of the rev limiter needless to say it had a slight tap very light i continued to drive it and
it started backfiring when the revs were over 2800 rpm blew the air flow gauge right out of the stock air box eng light is blinking over 2800 so im having a missfire so i pulled the pushrods and there were all straight so im stumped unless i bent a valve or something what do u guys think, thanks
in advance................................Frank
that almost sounds like a trans problem... I'd drop the trans and see if it will turn over...
things to do:
drain the oil
look at plugs
looks for leaks/anything unusual
discolored coolant
Just some ideas...
things to do:
drain the oil
look at plugs
discolored coolant
Just some ideas...
ive got a timing issue its backfring threw the throttle body and im gettting a check engine light flashing which means a misfire pushrods and rockers are good whats next??
