Heres one for you tech heads.....
Old Oct 1, 2005 | 03:08 PM
Ruffrider5.3's Avatar
Does it turn over real easy like it has no compression?
Old Oct 1, 2005 | 03:56 PM
ATIBlownZ71's Avatar
All the fuses are good. One of the first things we tried was the old school carb trick and nothing happened. Did a compression test and every cylinder is 185 +/- 3. The reason why it spins so easy is everything is teflon coated, it has very low parasitic friction loss - lol I guess it has no friction loss right now since it won't run. All the injectors are firing, they have a good atomized spray. My brother and his friend are both techs and have tried everything imaginable, but now they're saying might have to repull the motor and start tearing it back down to see if it is a mechanical failure of some sort.
Old Oct 2, 2005 | 10:44 AM
MonteCarlo31's Avatar
Have you tried an injector test light (autozone/napa) or are you going off hp tuner? It sounds like a VATS or injector issue to me. are you sure that the throttlebody is moving and allowing air in?
Old Oct 2, 2005 | 10:49 AM
budhayes3's Avatar
PT's Slowest Truck
I was also gonna suggest a possible bad tank of gas, but you already tried starting fluid in the intake and it didn't even cough. Is the spark a good strong spark? good enough to jump the gap on a HEI spark tester?
Old Oct 2, 2005 | 12:15 PM
We have it jumping a 1/4" gap. Throttlebody blade is moving. Swapped out the BCM with a known good module. Swapped out the TAC with a known good module. IT's starting to look like we're gonna have to pull the motor again and start looking deep for a mechanical issue.
Old Oct 2, 2005 | 12:21 PM
budhayes3's Avatar
PT's Slowest Truck
Damn that sux
Old Oct 2, 2005 | 02:35 PM
chevyerett's Avatar
I'm thinking valve train. You're getting a spark and injectors are firing. Valves may not be opening to let ne air & fuel in??? Definitely let us know what you find out. Mind boggling to say the least.
Old Oct 2, 2005 | 04:07 PM
You have confirmed that it is getting air, fuel, & spark. That only leaves timing. I would check the timing chain/gears, make sure that you do not have it a tooth off. Not saying that it wasnt put together right, I have just seen it happen a WHOLE lot. It would be the easiest thing to check mechanically. If it is off a tooth, go ahead & start buying some valves! Good luck
Ryan
Old Oct 2, 2005 | 08:19 PM
Im going with valve.....whose with me?
Old Oct 2, 2005 | 08:48 PM
PappyDan's Avatar
Tribe Shaman
fuel, spark, and compression, motor will not run,
54 psi fuel pressure
185 compression
plugs throwing spark
But still will not run after running for 2 days.
I say something came lose, something simple is not connected or is barely in the plug socket that is keeping it from cranking over.
If a wire plug came lose on a sensor it will not tell you that sensor is bad because it cannot read it, it is not plugged in, it will not even through a code unless it is running, witch is something it wont do right now but it did run for 2 days.
