Help with O2 sensor codes...
Old May 16, 2015 | 09:57 PM
Gadgetized's Avatar
I didn't see anything that jumped out at me in the tune. Did you by chance cut wires for something else thinking you might never hook rear O2 sensors back up? I would think the easiest check now would be to check the resistance at the plug vs at the PCM.
Old May 16, 2015 | 10:57 PM
GMCtrk's Avatar
What base tune (vehicle) is that OS for?
Old May 16, 2015 | 11:44 PM
Ferocity02's Avatar
I didn't cut the wires. They have continuity from the sensor to the PCM connectors.
The tune is for a 2001 Silverado 5.3L. It was downloaded from EFILive.
Starting to think there is an issue with the PCM.
GMCtrk's Avatar
Segment swap back a 4l60e tune and see if they work
Old May 16, 2015 | 11:46 PM
Ferocity02's Avatar
I'll flash in a 100% stock tune with 4L60E and try again tomorrow.
Old May 17, 2015 | 10:57 PM
Ferocity02's Avatar
So I flashed in a 100% stock tune and am getting the same problem...
I have no idea where to go next.
Old May 18, 2015 | 03:10 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Try a Spare PCM
If any of the NEW 02 Senors were not covered they could be bad. They typically have a cap or plug over the top of them so they don't corrode internally.
What Brand were the VatoZone sensors? I have had problems in the past and not just with GMs but other cars when not using Original Equipment brand 02 Sensors.
Old May 18, 2015 | 02:17 PM
Ferocity02's Avatar
Try a Spare PCM
All three sensors (2 from eBay and 1 from Autozone) are Bosch 13474. All had caps and looked new and in good shape. I can't imagine that I got three bad sensors in a row.
Old May 18, 2015 | 02:27 PM
01silvy's Avatar
When i said disabled thats pretty much what i meant about disabling the codes for no ses light. Still no luck?
Old May 18, 2015 | 02:37 PM
Ferocity02's Avatar
No such luck, even with a 100% stock tune.
