HELP!!! Nelson efans wiring harness
Old Oct 31, 2004 | 10:25 AM
piratebaseball's Avatar
Default HELP!!! Nelson efans wiring harness
Hey guys,
I'm trying to finish up my efans and I have the nelson wiring harness that I bought from somebody so I don't have his directions on it. I noticed that the AC wire on the harness has a pink male slot connector (assuming thats the technical term for it). Where exactly does it go. I have the plastic shroud off of the fuse panel so I can look at all the wires in there. Also, I know that the pcm wire goes to blue 42. However, there is some yellow stuff that GM put in there from the factory as well as all the other blank openings. Do I need to get this stuff out somehow or just push the wire into the blue 42 all the way in? I've found a good power and ground so that isn't a problem. Any help that you guys can give on the AC and pcm would be greatly appreciated. I'm going to lunch and I"ll check the forum when I get back to hopefully have some info so I can finish this project. Thanks!
Landon
PS: I've already programmed the pcm with hp tuners so that is not an issue!
Old Oct 31, 2004 | 11:27 AM
11 Second Club
You can piggyback the ac wire to the green ac wire coming from the compressor, and you poke the pin through until it bottoms out.
Old Oct 31, 2004 | 02:09 PM
moregrip's Avatar
what a rush!
Originally Posted by piratebaseball
Hey guys,
Landon
glad to hear you got the package enjoy!
sorry I can't help with the e-fans
Old Oct 31, 2004 | 05:20 PM
Hey man, thanks for the reply. I knew it was green wire but I couldn't figure out how the connector on the nelson wiring harness was going to butt connect to the wire. So I wasn't sure if it was meant to go in that area or not. Anyways, I just cut the connector off and scotch locked it into the green ac wire. So the fans work great and everything is nice and factory looking. Thanks!
Texas5.3_1251
Mar 5, 2016 08:10 PM
Silver8ado
Sep 14, 2015 06:35 PM
spooneralmighty
Sep 11, 2015 02:28 PM
97gmc
22
Sep 8, 2015 10:56 PM
muncie21
Sep 7, 2015 09:55 PM
