Help me choose a cam for a 4x4
Old Sep 29, 2004 | 08:02 AM
  #21
12sec.5.3's Avatar
Originally Posted by GregM
12 sec.5.3
Tell me more about your setup and how it acts thru the powerband.
GregM
My truck is pretty strong throughout the whole powerband. A stall converter is ideal for all vehicle's if you ask me, especially in a 4wd. The engine will not bog, and that's what you're looking for. With a stock converter my 212/218 does not have as much torque from idle as a stock cam would, but w/ the yank, at 3000 rpm you'd have to be in a serious bind to bog the motor-something would probably break first. IMO, you shouldn't go bigger than the 212/218 b/c you will put your power in the 6000+ range. Again, I would put the converter first.
Old Sep 29, 2004 | 09:07 AM
  #22
Mr. Sandog's Avatar
The application really has to be known before making a recommendation. If this guy with his 4x4 has a habit of attempting to go through mud bogs at top speed, then a new cam with a 2600-3000 stall is great. However, if he goes 4-wheeling in a traditional manner, which could entail 1 mph crawls through trails, and over rocks and boulders, he'll be royally screwed with anything over a stock converter. A slip of the wheels, and he could end up stuck, or inverted.
So I don't think your statement holds true - that a stall is good in 'all vehicles.'
Old Sep 29, 2004 | 12:52 PM
  #23
I've been considering a cam for my truck and have been playing around on an old desktop dyno program with some cam profiles. I'll say that a properly choosen cam will increase power thru the entire usable powerband.
Of the cams I tested, the Comp XR259HR(206/212) showed the most TQ at 2000. Other cams with 208/216 and 210/218 showed slightly lower TQ at 2000 but seem to quickly make up for it in the mid-range and at higher RPM's, while still matching or bettering the stock TQ at 2000 rpm's.
Now this was a make beleive motor on a computer program, so I can't say how well they will work in real life.
Old Sep 29, 2004 | 12:56 PM
  #24
marc_w's Avatar
That sounds pretty accurate, Silver...
There was a pretty in-depth "low duration, tight LSA" thread in the LS1 internal section... There were a few of us out there looking for torque cams. What you stated above, sounds a lot like what another member also found...
Old Sep 29, 2004 | 03:20 PM
  #25
Sport Side's Avatar
COUGH:listen to big tex.
I wouldn't hesitate to install a 208 208 XE high lift cam in a 5.3. Put it on a 114 lsa no advance. 02 LS6 springs would work well with it too.
Old Sep 29, 2004 | 04:49 PM
  #26
Mr. Sandog's Avatar
Tex also said, that he did NOT say that no bottom end would be lost (which I take to mean that some bottom end WOULD be lost).
I do believe that the guy who started this thread saying that he wanted to PICK UP low-end torque. This tells me that the 208 cam is not for him.
Old Sep 29, 2004 | 05:06 PM
  #27
Sport Side's Avatar
Point is, a tight lsa, short duration, fast ramped camshaft with as little overlap as possible is going to be a great choice for his needs.
Old Sep 29, 2004 | 05:07 PM
  #28
Mr. Sandog's Avatar
Not if he wants to gain torque and keep his stock TC. Not just any 'tight lsa, short duration, fast ramped camshaft' will do. Anything over a 206 will cause him to lose low-end.
Old Sep 29, 2004 | 05:08 PM
  #29
Sport Side's Avatar
REALLY? please tell me how you know this
Old Sep 29, 2004 | 05:10 PM
  #30
Mr. Sandog's Avatar
With a 6.0L, maybe not. But with a 5.3L, yes it will. Futral, Cam Motion, lots of other people who know their stuff, the other guys in this thread, etc...I believe them.
