Help me blow my truck up
Old Mar 1, 2003 | 07:19 PM
Black Blown 02's Avatar
Default Re: Help me blow my truck up
Yeah, thats my next mod...laptop,wideband,autotap,ls1edit,those injectors, then more boost.
So I take it you didn't decide to sell the truck. You ever put the 11 lb pulley on?
Old Mar 1, 2003 | 10:53 PM
GMC SKI's Avatar
Still have the pulley in the bag it came in ..
Started to snow here in toronto go too cold to do more on the truck
Get the injectors from RC or splice in some F-body injectors and shim the rail up a little
There's a few guys that have done this to there fuel setups with sucess
Just becarefull with the truck limit those WOT blast ..We don't need another #7 piston incident
Have you dynoed your truck ?
Did you rework the intake on your truck ?
How many PSI are you seeing ?
Old Mar 2, 2003 | 12:06 AM
Jim, do you still have your Blown 5.3?????? Thats a bad *** truck. as for the 99 4.8. take all the after market stuff off, return it to stock. take it to the dealer for an oil change. leave the dealer, unblot the drain plug, and drivr=e it down the road till she pops. Blame it on the dealer, and you got a new motor. Just an idea. ( This information is for fictional /hypothetical use only. The person that made this post will not be held liable for anything as a result. This product has been known to cause cancer in labratory animals in the state of califonia. User discretion is advised.)
J
Old Mar 2, 2003 | 12:08 AM
silent1's Avatar
Pour some coolant down your intake and fire it up. This will/should throw a rod and kind of make it look like a severly blown head gasket. This was what kind of happened to my original motor except I was four wheelin' and put the truck in a swamp. The truck died and when I went to fire it back up my #7 rod went through the side of my block!
Old Mar 2, 2003 | 12:15 AM
Thats a damn great idea. Just removeall the after market **** first. That way you wont have to deal with any bs
Old Mar 2, 2003 | 12:33 AM
GMC SKI's Avatar
Yeah i still have my 2002 Sitting in the driveway with 6 inches of snow on it
I have some plans for it this spring <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
want a spot in the top 10 for sure this year
Old Mar 2, 2003 | 11:03 AM
Haven't dyno'd, still stock intake, seeing 8psi at 5800rpm. I live at 4400 feet elevation, so i'm seeing probably 2lbs less boost than I would at sea level. Also my dyno #'s would be 20% lower than guys at sea level. My G-tech says I'm putting 320 to the ground (probably not that accurate)
Old Nov 9, 2003 | 08:04 PM
bump to the top. i really hate to be a digger but i wanna know how this ended up. did you blow the stock motor? and if so then how?
Old Nov 9, 2003 | 08:50 PM
BigTex's Avatar
Good question Jeff - What was the outcome?
Old Nov 9, 2003 | 08:58 PM
XLR8NSS's Avatar
Adkoonerstrator
Don't think Jim blew up his old motor. Here is a post about his new setup.
https://ls1tech.com/forums/showthread.php?t=109926
