Help with LS1 edit on a 8.1 truck
Old Jun 29, 2004 | 12:42 AM
reelcrazy's Avatar
Default Help with LS1 edit on a 8.1 truck
We are in the middle of some dyno testing an 2002 8.1 with LS1 edit. We keep having power (throttle back) cut off at 4900 rpm. This is happening even with the DLP drive line protection programming turned of in the computer. Anybody else run into this problem and if so were you able to get arround it?
Thanks
Reelcrazy
Old Jun 29, 2004 | 09:34 AM
CARAZYCUTER 4.8's Avatar
Thanks
Reelcrazy
send me your edit file & let me see what you have, list you mods when you send it
Old Jun 29, 2004 | 05:04 PM
Does the '02 8.1L have electronic throttle control (ETC)? Have you disabled or maxed out all of the ETC tables (including ETC rev limiter)?
Old Jun 29, 2004 | 10:44 PM
HAZE's Avatar
that's what i was thinking. engine>idle&limiters>etc. mine is set at 5400 though. which does'nt matter to me much since i don't have etc. also check speed limiters in the speedometer table. e
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
Velocity1
Jul 8, 2015 11:52 AM
Black-Syde
Jul 6, 2015 02:12 PM
