HELP! Lost transgo instruction sheet!
Old May 3, 2004 | 10:08 PM
bigguy75inches's Avatar
Default HELP! Lost transgo instruction sheet!
well.. title says it all,, i am going to install my transgo kit tomorrow, and low and behold, my instructions are missing! i still have the video,, but i know the instuctions tell more. so is there any place to download them, or email them to bigguy6f4@hotmail.com
Also i got a recommendation on not even putting any of the washers that increase the shift performance in. the kit comes with 3. i do have teh corvette servo. should i not use any, or maybe 1?
Old May 3, 2004 | 10:44 PM
revolution's Avatar
i just threw my intructions out.. sorry man.. i didnt put a washer in, but now i kinda wish i had. if you have a stall, go with one washer. the instructions vary from the video. hopefully you can find them. or call transgo?
Old May 3, 2004 | 11:19 PM
Last Call's Avatar
TOTM: January 2007
I got the Transgo shift kit with the corvette servos too. I didn't put no washers in and it shifts fine. If you have a stall converter you may want to addd a washer or two. With the radix, it spins the tires when it shifts from 1st to 2nd. As far as directions, not sure where they are. Good luck man.
Old May 4, 2004 | 06:03 AM
BigKID's Avatar
If I had my scanner working I would scan them for you...
I originally put one washer in and ended up taking it out because it was too much. Even now with now washers, vette servo and tt3000 I bark the tires at anything over 1/2 throttle.
Old May 4, 2004 | 06:06 AM
mudz5.3's Avatar
Bigguy, call me. Sent you an email. If you have access to a fax, I can fax them over to you. If you are going with a stall, do install 1 washer, if no stall, no washers. Any questions, ask hitman, flyer or myself.
James
SloSVO
Nov 22, 2020 07:34 PM
Wolftrk99
Dec 3, 2015 08:12 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
jscherbs
Sep 30, 2015 07:54 AM
Pimpinpete
Sep 8, 2015 07:39 PM
