Help Identifying Engine Harness Connector
2 Attachment(s)
Doing a V6 to LQ9 swap and while mocking up where the connectors are... there is one I can't figure out where it connects. The harness is from a 2002 Yukon 1500 4L60E and the engine from a 2005 Escalade.
Thanks -Red Attachment 155209 Attachment 155210 |
engine coolant temp, side of the block near the front
Originally Posted by About20ninj45
(Post 5436460)
Its EVO, goes on the back of the PS pump, if you have an EVO pump. Coolant plug is black. If you dont have an EVO pump, just ziptie the connector out of the way, and let it ride. |
Good to know, learned something new
Originally Posted by arthursc2
(Post 5436462)
Nope
Its EVO, goes on the back of the PS pump, if you have an EVO pump. Coolant plug is black. If you dont have an EVO pump, just ziptie the connector out of the way, and let it ride. Never seen a PS pump with a sensor (retired old school body/paint guy). Is it for trucks with hydroboost brake systems? |
Originally Posted by RedXray
(Post 5436477)
Thanks... I'll let her ride!
Never seen a PS pump with a sensor (retired old school body/paint guy). Is it for trucks with hydroboost brake systems? EVO is Electronically Variable Orifice. It is a system GM has used forever (my 93 Saturn SC2 had it), and basically it lets the PCM vary the steering assist based on vehicle speed. I also recently learned that on the NBS trucks, the EVO is trash and most dont work after a few years. I did hydroboost on my Tahoe last weekend, swapped out the OEM EVO pump (didnt even know it was there!) and I felt no difference at all in the steering. Granted, she has not been up to highway speed yet, but low speeds felt the same with EVO pump and with hydroboost pump |
