help to get faster???
Old Oct 21, 2011 | 11:19 AM
chevy_silverado07's Avatar
Default help to get faster???
Ok guys so its that time when you feel like u need more power I already have a 5.3 with intake longtubes and exhaust plus servo and wheatley tune what else can I bolt on for more power?? Not trying to go over 500 so turbo and supercharger are out....help?????
Old Oct 21, 2011 | 12:40 PM
Gh0st's Avatar
Jedi Master
cam, obviously
Old Oct 21, 2011 | 01:37 PM
only thing its my daily drive so cam is a little heavy i believe??
Old Oct 21, 2011 | 01:47 PM
gamble686's Avatar
A cam shouldn't be out of the question for a DD. As long as you don't get over aggressive you should be just fine. A 212/218 would be a great DD cam if your looking for just a little more. I think a better choice would be a small stall. Something with like a 2600-3k stall speed would be just great. That will give you whole shot power. It will be a very noticable change as many people drop .2 or more on their 60' times and .5 in the 1/4 isn't uncommon. Just my 2 cents.
Old Oct 21, 2011 | 02:27 PM
thanks for the advice now i guess my question is what is the price difference between a cam and a stall im not sure what a stall does always been interested tho
Old Oct 21, 2011 | 02:39 PM
gamble686's Avatar
Stall from Circle D=400
Cam kit=700ish
Basically a stall allows your motor to get higher in the rpm range before putting power to the ground. (kinda like dropping the clutch in a manual at 2k vs 3k)
Old Oct 21, 2011 | 02:46 PM
gotcha that price is with install? if it is cam sounds better and more hp am i right
Old Oct 21, 2011 | 03:44 PM
ak2007r6's Avatar
Can will give you more hp and torque. The stall just let's the engine build its power more by allowing it to rev more before the power is transferring it to the wheels.
both would be a great combo
Pretty sure those price don't include install
Old Oct 21, 2011 | 06:11 PM
Ok thanks for the help definitely doing cam first now just which one an wat size? And do I need push rods and rocker arms
Old Oct 21, 2011 | 09:10 PM
ak2007r6's Avatar
I am by no means an expert, still learning lots of this my self but from what I have read and been told you will need new push rods and rocker arms. Or at least it is highly recommended when doing a CAM swap.
