Help with exhaust sound
Old May 26, 2024 | 02:24 AM
viros's Avatar
Default Help with exhaust sound
Hi, i heard the perfect exhaust sound but i dont what the word is best to descrip it,
here is the videos
and this
what best word to descripe the sound
is not chop, right?
He are using customed by stock48 as i understand the specs are 224/224 111lsa based on triple12 cam, cant find the lift any where, you can find him in this blog by the name Jetn3
the exhaust used 4" downpipe from turbo with 4" corsa diesel muffler, thr engine is lm7 as i read.
Appreciate any help
Old May 26, 2024 | 04:54 AM
smokinlmm's Avatar
That’s chop, it’s from overlap. Not the best choice for boost.
Old May 26, 2024 | 05:23 AM
viros's Avatar
Why wouldn't be good for boost, and how can i achive this tone
Old May 26, 2024 | 06:31 AM
smokinlmm's Avatar
It’s dependent on the exact setup, headers, type and length, diameter of pipe, how it’s routed, h pipe or x pipe or none, resonators or high flow cats, muffler type and exhaust exit. There are many variables you would need to take a close look at the truck and ask questions. Choppy cams bleed off boost so they diminish performance with boost.
Old May 26, 2024 | 06:48 AM
viros's Avatar
does the header effect the sound even with turbo?. thanks for the info
Old May 26, 2024 | 01:49 PM
smokinlmm's Avatar
Its minimized by the turbo, but the turbo exhaust housing size, turbine exducer and down pipe size have a dramatic effect.
Old Jun 15, 2024 | 06:46 PM
infiniticrypto's Avatar
I certainly think the word "chop" has it's place when describing camshaft idle in many situations. With that said I'd prefer to use the older term "lope" here.
Old Oct 19, 2024 | 06:43 AM
viros's Avatar
misty solved,
it was triple12 camshaft. with turbo and 4" down pipe with turbo diesel resonator
Fast_six oh
May 17, 2015 05:54 PM
Frostflowz
25
Dec 5, 2012 01:13 AM
Spoolin
Aug 9, 2012 10:28 AM
BigDaddy0381
Jun 29, 2012 06:21 AM
AndysC3
Jun 28, 2012 03:32 PM
