Help with 95 454
Old Jan 10, 2009 | 05:10 AM
Big Chuk's Avatar
Unhappy Help with 95 454
I have a 1995 with a 454 that was running fine...Then I hit a Bull with it.
After the body shop got done with it It is Absolutely Gorgous! But it wont run worth a crap. It acts like its starving for fuel & backfires when driving or under any load.
I have replaced the fuel pump,pressure regulator,02 sensor,MAF.TBS,ECM,& on & on..
I had it a a garage he got an 02 code & thought it was the ground,so he Braised a peice of hard wire from the tail pipe by the sensor to the frame. It ran like a new truck for about 2 weeks then same problem back. It has a 1 wire 02 sensor. I don't know if it was something he moved when he was looking @ the truck & it went back or what.
It also has a brand new Hi-Flow cat. New intake gaskets. I'm tring to remember everything as we have replaced a grocery list of sensors & such.
It doesn't have a NEW Throttle body but it does have a different one a freind changed out.
Any help would be much appreciated as I hate to PART OUT such a fine truck,but I can't drive it.
Old Jan 11, 2009 | 06:25 PM
John Overton's Avatar
I know she took quite a hit hitting a bull! Check your ignition out, it is quite possible that the distributor cap could have smacked the firewall and got cracked. (if I remember right the '95 is TBI right?)
Old Jan 12, 2009 | 09:21 AM
shandy294's Avatar
Yeah,a bad cap can cause it to run like crap. Bad plug wires can look good and be bad under load. I know an accident wouldn't make them go bad but how old are they?
You can spend lots of money shotgunning parts.
dragpac
Dec 8, 2015 05:48 AM
Raylar Engineering
Aug 26, 2015 10:36 PM
Bret Kepner
Jul 12, 2006 08:07 AM
