Help with 90 silverado
Old Feb 27, 2007 | 05:05 PM
NegraRCSB2X4auto's Avatar
Default Help with 90 silverado
A friend of mine has a 90 model chevy with the 350 he says it's running rich any ideal what could be causing this. only thing he has is a kn air filter new injectors and a rebuilt motor. any advice is appreciated
Old Feb 27, 2007 | 06:27 PM
RoosterMcCandles's Avatar
If it is running rich and he got new injectors, I would start there...
Old Feb 27, 2007 | 06:42 PM
Ruffrider5.3's Avatar
Needs to be tuned for them there injectors.
Old Feb 27, 2007 | 06:45 PM
nightrunner's Avatar
Mr. Obvious
im thinkin injectors like everyone else
Old Feb 27, 2007 | 07:35 PM
YenkoST's Avatar
on a 90 with TBI, they are setup lean and those mods will just be leaner so I doubt its rich unless he is running 15 psi on a stock rebuilt engine. A 350 has 61 lb/hr injectors set on 11.x psi and 210hp stock so its not likely he is rich but if he has done a cam or put bigger 454 injectors or cop car injectors then he shouldn't be rich on a stock engine then he is rich then.
What's his mods exactly?
Old Feb 27, 2007 | 09:35 PM
well by say it's rich i guess that's what he means he says it smells like gas? (lol to myself because to me that doesn't mean anything other than he spilled some gas when he refueledLOL) anyways that's what he said i believe he changed the injectors because of this reason.
Old Feb 27, 2007 | 10:29 PM
YenkoST's Avatar
To what injectors though....if he put the 350 injectors in on a 350 engine, I doubt its lean. A rich smell can smell like a lean smell as well....he needs to log it and see. Moates has the stuff to do it with. He should be at 128 BLMs or higher at idle. 128 is 14.7 and higher is leaner.
Old Feb 28, 2007 | 06:11 PM
stock injectors same as old
Old Feb 28, 2007 | 07:00 PM
YenkoST's Avatar
Yea I doubt he is rich....those 61 lb/hr injectors are setup lean from GM to begin with with 11.x psi esp, if the engine was rebuilt to stock specs....however, if he put a bigger cam in it then it could be rich at idle but it would be very lean in the upper end.
6LITEREATER
Mar 4, 2026 06:13 AM
nickpc82
Nov 2, 2015 02:49 PM
85SS/85GN
Aug 7, 2015 04:30 PM
Shtbox
Aug 2, 2015 10:52 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
