help!
Old Sep 12, 2010 | 11:06 AM
05ls2chevy's Avatar
Default help!
does anybody know what motor the 803 heads cam off of?
Old Sep 12, 2010 | 02:12 PM
05ls2chevy's Avatar
anybody?? this guy is sellin heads and cam he said the heads are 803s but ill i can find are 806s which cam on the 1997-1998 ls1 vettes.. and the cam is a 221/221 lunati he said the cam has the duration numbers on it and a (2870 a) number and i cant find anything on that either... he said its for a ls base motor but cant find anything... thanks
Old Sep 12, 2010 | 02:26 PM
viciousknid's Avatar
Where's the Beef?
http://outintheshop.com/faq/casting/castings2.html
I too only find 806's.
as for the cam I found this for LSX engines.
Lunati 55004
Adv In/Exh Duration 283/283
Duration @ 0.50" 221/221
@.050" In/Exh .558/.558
@Lobe In/Exh .328/.328
Lope Sep Int C/L 114° Sep 110° Int C/L
RPM Range 2500-6000
Hydraulic Roller; Fair idle. Good all out street Performance or mild race cam. Valve train modifications necessary (valve springs).
There should be a grind number on the end of the cam. Can he get all of the numbers off the heads?
Old Sep 12, 2010 | 02:33 PM
05ls2chevy's Avatar
he said there 806 heads now for the cam thats all the numbers that were on the cam he said. duration number and that 2870 a number idk i guess ill what till tomorrow and call lunati
