heads and cam ?
Old Apr 3, 2012 | 05:26 PM
Whitelightin2005's Avatar
Default heads and cam ?
I have a chance to buy a set of 243 heads off of a 6.0 and a 224 cam. I have a 05 GMC with the 5.3. would like to get input if its a good set up or not. Of course gonna add headers and a tune after the swap and a CAI. Just checking before i buy on how its gonna be. Thanks guys
Old Apr 3, 2012 | 05:32 PM
dmelvin's Avatar
You'll need to mill the heads .030 assuming that they're not already milled to keep your current compression ratio.
Personally I think the cam is a bit big if you're not going to put a stall on the truck.
Old Apr 3, 2012 | 07:45 PM
Yes i plan on adding a stall in the near future
Old Apr 3, 2012 | 08:49 PM
grey matter 04's Avatar
13 Second Truck Club
that combo mill the heads .050 gain some compression and a 3600 stall with 410s it will run good
Cam is a bit big but will work
I prefer less cam and stall for my daily but its all in what you want!
Old Apr 4, 2012 | 06:15 PM
Am i gonna need to mill them .050 or .030?
Old Apr 4, 2012 | 06:37 PM
ltr450ryder's Avatar
I go .050 so u can bump the compression up for that cam
Old Apr 4, 2012 | 10:38 PM
.030 gets you back to stock compression ratio
.050 gains some compression
Old Apr 5, 2012 | 05:20 PM
Thanks guys. helps alot will post when i get it done
Old Apr 5, 2012 | 10:17 PM
SloStepSide's Avatar
Is more compression better? I only ask im looking into the samething only with a 220.
Old Apr 6, 2012 | 11:07 AM
more compression helps make a little more power and improves bottomend a tad
Basically yes it helps
GrooveCityZ71
Aug 31, 2015 12:05 PM
JFortner5
Aug 12, 2015 08:46 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
Aboss
Jul 9, 2015 10:28 AM
